high revving
beentryin
208
goshen,ohio
i have a well ridden gt5 with about 700 miles and havent ridden it in about a few weeks,ran great when i put it up,well started it ran great let it warm up went thru town and opened it up like normal,and when i let off the throttle,i was high revving,checked for leaks none,checked for throttle sticking works fine,but while it revving i can jump the clutch and slow the idle,and pull the clutch back in and it will idle fine rev it up and same thing,it use to have a very crisp throttle?any thoughts would help
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
Your symtoms are consistent with an air leak, somewhere. As was suggested, check your crankshaft seals, carburetor to intake and intake to cylinder, again. This is a common problem. The reason it seems okay when the engine is cold is that your air leak opens/increases due to expansion with engine heat.
Keep checking all sources of air entering the engine downstream of the carburetor.
beentryin
208
goshen,ohio
yeah i found the airleak it was there was no intake gasket,it was gone,kinda weird how it ran great sit fo r 2 weeks the bam ran like crap via intake gasket
