I installed a high compression/run cool head on my bike, I’ll add a link below to the head and also the engine I have. Anyways it didn’t do anything the bike runs the same also I did a compression test and the bike actually has 5 psi less with the high comp head. It was originally 105 now it’s 100. I thought it was going to raise the compression, i reused the original nuts/washer and tourque to 150 in/lb. I left it for a bit with the compression tester attached and it stayed at the same reading so I don’t think the head is leaking cause if it was I’m pretty sure I would see a drop in psi on the gauge. Also on a side note how fast should one of these go? Mine goes 40km/h. The ad says they come with a 36t sprocket but I counted the teeth and it’s actually a 44t I think it may need to be tuned or something too, if I hold the throttle steady at any setting between probably half to wot it bogs out/4 strokes I think, it will accelerate but then one it gets to a certain rpm just bogs and yea at wot it bogs/4strokes and just barely goes 40 km/h but yea it’ll also do it if I hold throttle steady at 1/2 or 3/4 quarter throttle and it quits bogging as soon as I accelerate. It’s all stock other then the head I just put on, I also adjusted the needle clip to one position up from stock cause it seems to run better that way and I run the exhaust with no baffle, ngk br6hs plug, 40:1 mix, i modified the air box for better air flow. The bike I have the engine on is 26” it’s pretty light, I’m 175lbs
motorizedbicycle.ca
66cc / 80cc High Performance Head
Compatible with GT5, GT5AWoody WoodPecker's High Performance / High Compression run cool head.Brushed aluminum finish. 6cc combustion chamber; Means high compression. It Fits 66cc and 69cc engines using M8 head bolts and 47mm dia. pistons. Extra cooling fins and extra mass means better engine...
motorizedbicycle.ca
