Attached are some pics of my build, from the ground up (kit wise !) - had mtn bike frame sandblasted, I painted with laquer base (suggest enamel base to others), most everything else is new - front forks, thudbuster seat post, etc.
This thing flies, the clutch is great. We have a lot of hills, I have a 56 tooth sprocket on the wheel, and would like to gear lower. The max size sprocket I usually see is 60 tooth, that isn't going to be enough for NH.
Right now, I am 30 mph +, I have been happy for the last 5 years at 22 mph and climbing hills with my Super Titan + Grubee 4G. I would be happy at 25 mph max with this new build, and hill climbing ability. I bought the clutch from custommotorbikes (thanks Lynn - you are great !) and the adjustable drive pulley she sells for the HF motor. I have this pulley opened up as far as possible without the belt hitting the aluminum of the clutch mount (see pic) for the lowest gear ratio I can get. I am not going to get lower I think with this arrangement.
Thinking of emailing EZM directly, to get a recommendation of a fixed drive pulley, smaller diameter for lower gear ratio. Wondering if I might need to put a heavier tension spring on the clutch, to pull in the slack of the belt better, I don't think the stock one will do the job with a small diameter drive pulley, where they will be a lot of slack ?
Anyway the clutch is great, and will be an improvment once I get the gearing down. AND there is another mod, besides defeating the governor (increasing carb jet with custom air filter) that AGK suggests for more power. But I got to get the gearing down. These motors are so cheap ! Beats buying a Hua Sheng for 2x - 3x the price, depending on type / power...
Oh, also see attached pic on my clamp arrangement to secure the EZM clutch to the frame as required by EZM. Made it from hardware store stuff + rubber pads from a sink mat (!) cut up. Not pretty, but will do until I have time to fashion a permanent clamp.
Thinking Gunther pretty good about finding / reading this things.
Yipee !
Big Kid
Yipee !
Big Kid
