HF 52cc Kill Switch
Albula vulpes
419
FL
Just a heads up...........................
If you have a Harbor Freight 52cc Water Pump engine and are looking for a place to mount the kill switch because it is not in a good spot, do not follow the example shown on BMP friction drives website. If you mount the kill switch on top of the engine with the kill switch bracket provided, It will break the bracket due to vibration because the metal the bracket is made of is weak. Trust me, I have broken two brackets having mounted the kill switch this way.
If you have a thatsdax friction drive, good news if you have broken kill switch bracket, you can take the switch off the bracket, and mount the kill switch in the extra mounting hole on the friction drive drive channel, you just have to drill a pilot hole to route the wire. You might wanna run some silicone on the back side of the kill switch incase it gets wet in this location.
