Hey just got an 80cc 2 stroke cheapie.. I've got it all mounted up and had it running for about an hour, went to lube up the primary big and little gears and the big gear is fairly sloppy? Is this right? You can move it back and forth about 1 mm and its got a fair bit of slop sideways too..
It doesn't seem right!
How does one remove the actual clutch cover to see what's happened.. Can you undo the little screw and with the clutch on undo the big center adj nut?
Regards and Thanks for any advice..
Nugget
Nugget
