Re; 80 cc
Clutch drive gear and magnito drve gears failed. After replacing both gears I think the timing of the gears is not properly set.
The engine will run , but it apears that timing is off ( fireing too early )
Any help will be appreciated.
Thank you
granpaj![]()
Hi 2door Re 80 cc
Correct me if I'm wrong the clutch assembly is attached to the crank shaft, the clutch gear drives a smaller gear ( both gears on the right side ) that turns the magnito ( via a shaft ) on the other side of the engine (on the left side ) I have replaced both gears on the right side
A kickback sounds like the timing is advanced a tooth or so
