blckwlfny1
I'm having a little trouble with using an internal gear hub on my bike.
I have a skyhawk with h/c head and a sbp **** kit
9t of the jackshaft
...To a 36t on the crank (larger will not clear the motor)
...A 24t on the inside pedal going to the rear sprocket
...A shimano 21t on the alfine 8-speed hub
The gear ratios work PERFECTLY for what I want. I don't have to use the pedals to move from a dead stop. And the gears are high enough so I don't WANT to go any faster (32 mph is fine)
The problem is NOT failure in the gears or freewheel of the hub. The problem is that the rear sprocket keeps breaking itself off of the 3 splines that hold it to the hub.
It will begin by popping free then catching a few times and then it will eventually spin freely. Does anyone have any suggestions on how to affix the splines more securely?
9t of the jackshaft
