HELP: Stripped screws and seized engine
Discussion in 'Motorized Bicycle General Discussion' started by Mheppert, Aug 13, 2015.
  1. YesImLDS
    YesImLDS Member
    Jun 29, 2013
    958
    Well said Tom. I currently run without a tensioner and did so on the last meet I attended. The chain is properly adjusted using the rim on the dropouts. Heck I just see it as another thing to go wrong. Lost a rim to the tensioner previously and it's also extra unneeded friction. But if you have to have it due to clearance issues it's better than grinding away at your frame or even your tires.
  2. Whiteride
    Whiteride New Member
    Aug 7, 2015
    31
    I've had zero problem with the tensioner which is a higher end non-sprung type and not the kit provided one which is arguably a POS as are most of the kit supplied components and among several of the kit items one should simply discard and upgrade from the get go. I have had issues keeping the crappy engine running. I think if you were to look at numbers more of these fail than last. Again and I'll try to keep this simple for you 2 strokes made in Asia are cheaply made and highly inefficient by the very nature of their design. It is of little surprise that they are well on their way to being banned. I only wish there was a 4 stroke alternative that had the same dimensions.
