help on making or buying a strobe circuit for my tail light
MaxPower
First off, I have never built a circuit. I do understand that electrical systems work by keeping smoke in the wires but that's about it. I would love to build my own flashing circuit and would really like some supervision on the project. I'm looking for either a place to buy an already built one (which would be no fun) or a sources for each components I would need. What I really like is someone to post links to parts and I could buy them all together as a kit. I know I'd need resisters, transistors, and capacitors from the research I've done but I have no Idea how it goes together. Maybe someone could give me an education on each component and how they work together.
here is the system I have on my bike.
2- 12v 55 watt halogen headlights
1- 12v LED tail light Walmart.com: Blazer 4" LED Oblong Combo Marker Light, Red: Automotive
1- 12 volt 8 amp SLA battery
negative ground on bike frame
My plan is to use a switch on my brake to turn the strobe circuit on or off when I pull the leaver.
Research 555 IC circuits. You will find tons of schematics and parts lists needed.
Very easy to make.
that's great I'm still a little confused on what I should buy. Is 1000 uf a type of relay? and what resistor should i buy?
I should of posted this picture before but this is what I was thinking. would your circuit work like this?
I'm still a little confused by your diagram. Can you draw it in plan language? what is NC and NO? If I put the switch to NO on the bottom switch does that turn off the strobe? and what does the top switch do? A and B wires look like they do the same thing?
Putting 12 volts into a 6 volt system will let out the magic blue smoke.
POOF!
It does not work anymore.
