ahdunno
Help Needed, No fuel flow
I blew an upper connector rod bearing and it took the rings too.
I installed a new bearing and rings and now I have no fuel flow.
Good compression (No gauge though) and I can feel a vacuum pull on the manifold with the carb off. It looks as though there is some fuel in the cylinder. When I pulled the head, the cylinder is wet but the plug seems dry with only a faint smell of fuel.
It has spark and I just tried fresh fuel mix, it just won't start.
I've also checked the float level and the inlet and jet on the carb (Stock NT) for blockage.
I also pulled the magnet to check if the key was OK and it is. The magnet seems to be in the correct position when the piston is TDC going by pictures I've seen on the web.
I'm baffled. Any input would be appreciated.
Thanks
Thanks
