thank you. the trike is my favorite also. it has functional signals, head ,tail and brake lights and horn. I installed a 12 volt magneto , regulator/rectifier and cycle battery, so it has a functional charging system. just install a billet high compression head(not in the pic) also have cdi box with advanced curve with 12v coil. 32 tooth rear sprocket, slower take off but better top speed. delloroto 15.15 carb, and banana expansion pipe installed. I have only test fired it so far, I built it in the basement over the winter. another couple of weeks weather should be a little better and will be taking her out for her first ride.
