After a couple months of use on the HD lightning something has gone weird. It all started out with terrible bogging at the top end all of a sudden after I fiddled with the fuel line. So first thought is to fix the fuel problems. I completely redid the fuel line with a 1/8" inner diameter barb going to 3/16" fuel line to a briggs and stratton 1/8" inner diameter petcock then continuing to the carb. The same problem continues. Maybe the jet is clogged up so I tear apart the stock carb and clean that out and the jet is clear. Checked wiring and the magneto and everything is in good shape. Spark plug isn't fouled and was switched with another with same problems. Essentially I went through everything to find out this ridiculously expensive CDI is the problem.
The HD lightning CDI was a hope for more performance on my performance build. Worked perfect for the first couple months, but never noticed anything different in comparison to the stock CDI. Now sometimes it'll work perfectly into the top end and have no problems for the next half mile then it'll bog down not having any spark at all to the point where I was thinking that I was just starving it of fuel and I'd pull in the clutch and try to get it to free-rev.
I guess what I am trying to get at is has anyone else had a problem like this? Am I over looking something by chance? I don't want to have wasted $70 on a piece of junk plastic to go back to the stock CDI that has like 5k miles on it between three evolving builds.
