Not that I'm aware of, I follow the progress of such unique mods very closely. However don't let that stop you. Get plating that will handle chrome rings, as most of the rings I can find are chromed.
I'd be wary of the larger piston though. The pistons included in our engines are already fairly light compared to others, a larger piston will weigh more and your engine balance will change, most likely for the worse as (most of) the cranks are designed for 48cc engines. This means your piston assembly needs to be lighter, not heavier, to reduce vibrations and ride in a comfortable range.
