Do I have 50cc GY6 that is currently stock, It rubs and have ridden it around but the moment you give it some decent gas and then let it idle again it tends to try and die I have adjusted the idle screw so it ran a little better but it still won't run properly after I give it some gas.
I have heard that the 24mm Carbs that come stock with the GY6's are pretty bad and read that a 26mm solves most of peoples problems.
Is there anything anyone can think of that could fix it ?
Also what makes a standard carb different from a performance carb other that the 24mm vs **mm (e.g 26mm)
Thanks Drew
Thanks Drew
