Ballin on a Budget
Hey guys, I thought I'd just quickly share the mods Ive done to my new build so far since they have netted me some great benifets! At the moment, money has been a limiting factor, but that still doesnt change the fact that I love to tinker and get the most out of my setup (66cc HT).
Here it is...
-Upgraded spark plug to NGK BR7HS (much cooler than stock)
-Upgraded 7mm plug wire
-Port matched the factory intake manifold pipe and gasket
-Port matched the Exhaust pipe and gasket
-Shortened my intake manifold pipe by 3/4"
-Heat wrapped the exhaust header
-Took apart the factory muffler (center bolt style) and cut off the 1/2" pipe
-Drilled two 3/8" holes in muffler cap as well as internal baffle
-Made a velocity stack for my intake with a nylon (womens tight) filter
-Soldered all electrical connections
-Moved my c-clip on the carb needle down one notch (richer mix)
So far these mods have cost me under $20 but have truly made a world of difference (enough so to compel me to tell others about it!) both in power throughout the rpm range, top speed, and most importantly in how smooth my engine runs. I guess its just the right combo of small upgrades (more air in, more air out, and slightly more fuel to match) that just work well together.
One thing I will say to anyone performing these or any mods to their setup is that EVERY motor is different and will react slightly different to each mod so do this one step at a time and at your own risk. Also, any time you modify your intake and exhaust to upgrade flow, remeber that you will also increase sound output. Anyways just thought I'd share a few things you can do for very little money to help your bike run better and get a lil more power!
-Dan
Here it is...
-Dan
