Grease bearings under clutch plate??
Discussion in 'Motorized Bicycle General Discussion' started by Mean.motor, Oct 31, 2014.
  1. Mean.motor
    Mean.motor New Member
    Mar 14, 2014
    35
    i have a question, the little ball bearings under the clutch plate around the clutch's rotating disc on the inside(you can barley see them in there) is it ok to grease these as they are moving parts. I did do this in my older engine twice and noticed significant clutch response and it was very smooth. though the second time i did put too much grease and noticed clutch slipping after about 20 kms. I haven't done this with my new engine yet but want too unless advised otherwise..xx.
  2. Mean.motor
    Mar 14, 2014
    35
    heres a pic of what im talking about..
  3. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,778
    89
    those bearings are crap & probably won't benefit much from grease - too much there can ooze out onto the pads too - I used to take it out and from the backside, pack a bit of grease thru the three holes there, but I don't bother anymore
    if you want to try it, put some grease into a nut & hold the nut over one of the holes, slowly screw a bolt into the nut while rotating the bearing an inch or so while doing it - stop if you see grease leaking out on other side
  4. maniac57
    Oct 8, 2011
    4,486
    7
    I use light oil on them rather than grease. MUCH easier to clean off when you get it on the pads.
    Never noticed any difference.
