mogollonmonster
Ideally, I'd like to hook my ChinaGirl to some kind of transmission, one with input and out put, both on the left hand side of the bike. I would like to leave the pedal drive side alone. A ChinaGirl compatible CVT would work too.
As I believe I'm asking a bit much there, so...
Anyone using the Dax shift kit? Is it equal to the SBP kit? Through extensive digging on this forum, I found little. I'd like to stick with Dax, but if I'm going to drop the money, I'd like the best.
There was some question as to weather or not the Dax unit was "HD", like the one available from SBP. If you are using a jack shaft kit, are you shifting via IGH or derailur? Which is the more reliable?
I'm really only looking for two speeds, one just about direct drive from the engine, and an underdrive for the steeper hills. I think a CVT would work ok for this, but I've yet to source one for ChinaGirls. A self contained unit appeals to me over a jackshaft kit, because I'd like to keep the engine ans pedal system segregated. If I have an issue, I just pop the master link, put the chain over my shoulders and pedal...
