mew905
So, I'm thinking, when I switch up the bike, I wanna go with a front electric motor, something with plenty of power (and ungoverned), say capable of 25-30mph, though I wont complain if its faster. range isn't an issue, I need it to have regenerative braking (or something that can charge while rolling) so I can start with the electric until it runs out of juice, then run the gas motor, then go back to the electric motor when it's either charged or I run out of gas (hence why I want one that can charge while rolling, or maybe even trickle charge it with the gas motor). Of course the gas motor will be capable of much higher speeds (most likely anyway), but I want the electric to maximise range, and for short/pleasure cruising, or even assisting the gas up steep hills or in case something happens with the gas motor.
I live in canada though and cant seem to find much. I expect to pay around $500 for the hub, battery and controller. Regenerative braking would be a plus, and a small rack mounted battery would be good as well. If at all possible, a left-side thumb throttle or twist throttle would be ideal, or if one exists, a brake/thumb throttle combo on the right so I can use both throttles easily. Any assistance getting this accomplished would be greatly appreciated, just, like I said, i'm in canada so they either have to be from here, or ship to here. I'm willing to go separate parts because my wants from a kit arent exactly ideal.
