First time for everything - Clutch Pads Install and test drive
clutch pads rarely wear out in less than 3 or 4 thousand miles unless clutch isn't adjusted properly
on a side note, read on the forum about what happens when you put rubber into those motor mounts - I recommend putting a bit of PVC pipe between that rear mounting block and the frame
I like very much your description about the mind-clearing effect of riding these - ride on.
thank you for the info i did read the forum thats scary i think i will try your idea those blocks seem to fit weird i knew something wasnt right!
