I built this frame last year and have dune several modification's to it already it has been a very reliable ride. so I thought it was time for a new mod a 2 stroke engine 48 cc through rock solid engines, had no problem with them ordered it using COD took longer to get the package notice from my local post office 200 meters down the road then it did to send the package interstate any way the frame is mostly home made rear triangle was stock as well as the bottom bracket the front triangle i made and was attached to the rear bottom bracket swivel since installing the engine i have had to remove the rear shock.
my only mod that i have dune to the engine at the moment is the exhaust i needed to change the angle to clear my peddles then it ran into my stand mount which is welded to the frame simpler to move the exhaust in out over and around then the part of the frame have only had few small test rides, i have painted the clutch cover, magneto cover and sprocket cover and since taking the photo the exhaust.
