anim8r
My Black Squirrel ("The Flying Fart") was just too problematic. Spring is here, & I wanna ride. So I stripped my old cruiser down with a heavy heart & hung it in the garage for now. Who knows? Maybe it will become my 1st tadpole one day. Sure was a cool bike, & I'll miss it.
So now I'm working on Tundro, an (ahem) all-terrain beast named after the triceratops-lookin' thing from The Herculoids.
This one won't be nearly as fancy as the old one. I'm just mounting a motor on a bike, simply as I can.
The 1st thing I'm concerned about is the mounting.
The pic isn't very clear, but it shows a slight gap between the mounting block & the bike's downtube. This is caused by a weld from the manufacturer.....there used to be a bottle holder there, but it was in the way so I removed it & the hardware. What's left is this nice little hole that kinda looks like a washer welded to the tube. I'm afraid the gap & bump might put pressure on the mounting block & cause it to eventually break......
I had to make some new mounting studs from threaded rod since the Flying Fart had custom U-bolt mounts (& I cut the old mounts down to use as fender bracket hardware).
Aside from the bump, the motor sits pretty nicely in the frame.....except for 2 things:
1) the left pedal hits the exhaust pipe. Gotta bend that in.
2) there doesn't appear to be a lot of room for the throttle cable to screw into the carb. Really hoping that won't be a problem.....no time to find out today.
