Agreen
It started with a weird condition at WOT. After riding at WOT for a minute or 2 it would kind of bog. I thought it was 4 stroking. Never had much experience tuning 2 strokes. On a car, lean will surge and buck, and rich will bog. Turns out, on a 2 stroke it will braap at you when rich, and bog when lean.
So I started reading up on how to tune the jet of this NT carb. Sounds simple enough. I have everything I need except some tiny drill bits, let's get to it!
I read all about how the carbs come tuned too fat out of the box, so I bring a spare jet with me. It came out of another NT carb that broke one of the little clamp tabs. I found that a 69 didn't fit, and a 71 did. The hobby shop I bought the bits from only sold individual bits, not a kit. Unfortunately, he didn't have a 70, so I guess that could be the stock size? Anyway, I get everything from a 69 to 74, thinking I would never need to go bigger, but I just grabbed the 69 bit anyway.
Now, I'm not sure if it was because of the "poopoo pipe" I slapped together in a rush, the transfer ports that I barely gasket matched, or the fact that I shaved my head about 0.005" because it was warped...
Really, none of those should matter much. When I started tuning the carb I went down to a 72 at first. Hmm, not sure why but it didn't feel right. It would straight bog down at anything over 3/4 throttle. Weird, but maybe it's still too rich?
So after getting worse and worse the leaner I went, I finally got the hint. So I pulled out the #69 bit and gave it a go. Instantly, I knew I had found it. Not a single bit of bogging (and definitely not 4 stroking). Although I will say that the idle suffered a bit after rejetting, so I leaned the needle down and fixed that.
Now I'm going to make a CDI to get some better spark. I'm kind of curious just what I can do with this little guy!
