The list--pictures--- 1.Compressor -- 2. Spray gun ,,,, pic 1. Specs- Compressor pic 2. Specs . spray gun .... Compressor
2 HP motor
Automatic shutoff
Twin horizontal tanks
Anti-vibration rubber feet
120 volts, 16 amps
60 Hz
3400 RPM
115 PSI max working pressure
Air delivery: 4.4 CFM at 90 PSI, 5.8 CFM at 40 PSI
Air outlet: 1/4"-18 NPT
Overall dimensions: 15-1/4" L x 15-3/4" W x 17-3/4" H
2. Specs- Spay gun Detail Spray Gunfinishes. Internal mix design with air flow adjustment screw.
Fine spray adjustment
One quart siphon cup with chrome finish for a professional look
Internal mix spray gun
Reinforced base, cam lock closure
All metal construction
For detail work
Operating pressure: 50 PSI
Air consumption: 12 CFM (stated), 1.5 CFM @ 30 PSI suggested
Nozzle size: 1.7 mm
1 quart paint capacity
Air inlet: 1/4'' - 18 NPS
2 HP motor
Automatic shutoff
120 volts, 16 amps
60 Hz
3400 RPM
For detail work
Nozzle size: 1.7 mm
