rackemblue
You all do not have to worry about me shareing any information any more. I found out that my information is not welcome so do what you want too.
You all do not have to worry about me shareing any information any more. I found out that my information is not welcome so do what you want too.For those of you who do not know the importance of letting the engine warm up for five minutes before takeing off on your bikes for the first time of the day or night. This information I learned in Motorcycle school. The pistons in all bikes are slightly cone shaped smaller at the top than down at the skirt. The reason for this is the top of the piston is going to expand more from the heat on top from all the little explosions of repeated fireing. After they warm up they are steight up and down on the walls from the top to bottom of the piston. The cylinder and head of aluminum also expands and contracts on their respective gaskets. So if you take off before they have expanded your piston is rattleing at the top from being loose in the cylinder and oils and compression can leak from your gaskets. That is what causes the most engine failures or excessive wear and blow by from your head gasket and base gaskets. Harley found this out the hard way when they went from the iron heads and cylinders to the aluminum Evolution motors. We had to change out many cylinder base gaskets and head gaskets under warranty. They were blowing oil every where. They then started changeing gasket material and looking for why until they realized how long it took to warm up and tighten up on the gaskets. Takeing off with a cold motor puts crank case pressue on gaskets and causes them to leak or blow out.![]()
doesnt matter what kind of two-stroke it is. "Crudely" constructed or not, on a brand new bore, it still requires being properly broken in so the rings can cut into the crosshatch surface and evenly seat into the bore. if it isn't done properly, and the apex of the crosshatch becomes "polished" over before the rings cut in, they will never be allowed to cut in properly and evenly without being honed and new crosshatch lines put in. Without seating in correctly, the engine will never perform well at all.Much to do about nothing. These engines are so crudely built that it’s really amazing the run as well as they do. There’s absolutely no temperature regulation on them. Ride one in the winter and it’s likely running 100 degrees cooler than riding in the summer. By the way, compensating for expansion is generally done in the cylinder bore, it’s called choke bore and when cold the top is tighter that the bottom, when hot the top expands so that the bore is the same from top to bottom. This is how aircraft air cooled engines have solved the problem for about 75 years.
BS. These things are literally made in peoples back yards in China. That’s how they can sell an entire setup for $80.00. There is zero quality control. Pay your money and take your chances.doesnt matter what kind of two-stroke it is. "Crudely" constructed or not, on a brand new bore, it still requires being properly broken in so the rings can cut into the crosshatch surface and evenly seat into the bore. if it isn't done properly, and the apex of the crosshatch becomes "polished" over before the rings cut in, they will never be allowed to cut in properly and evenly without being honed and new crosshatch lines put in. Without seating in correctly, the engine will never perform well at all.
Wrong, and as stated, a two-stroke is a two-stroke, it still needs to be broken in properly, regardless of who made it, or how, or how good the quality is. Even if it is lower quality materials and workmanship, that makes proper break-in procedure even more of a prevalent necessityBS. These things are literally made in peoples back yards in China. That’s how they can sell an entire setup for $80.00. There is zero quality control. Pay your money and take your chances.
