Ancient Order
Whenever I'm going up a hill or starting off my engine will start to make a weird sharp buzzing sound and lose power. Is it not getting enough air/fuel? Whats making that sound?
Thanks
Thanks
what motor /kit?
If you think this is abnormal then you should remove the covers at least, make sure it's not a chain/tensioner problem, turn the crankshaft with a socket magneto side and try to feel irregularities, etc.
Have you played with anything that could've change the air/fuel mixture? (Airbox, exhaust, leak?)
Have you got free flowing fuel? Maybe the gas tank isn't venting properly.
What color was your plug. I suddenly had this problem today on my 66cc Flying Horse. Moved the c clip one notch up (top) too. I didnt have this problem until I checked my plug earlier today. Suddenly while riding the bick started jerking back and forth when i hit my first hill. So far it seems to be running better with those adjustments made. Is your rear sprocket aligned properly. just a little off could cause slack and tension in your chain making your bike act like that.
Kevin
