I saw a post for this mod to make the clutch much easier to pull.
Pretty simple setup, using a screen door roller and a piece of square tubing.
I finally got around to putting it all together.. and all I have to say is... WOW!!!!
Ok, I guess I really do have more to say.. LOL
It seriously has to be 500% better. I actually couldn't believe how hard you have to pull on the stock setup, seeing how cheap some of this stuff is. With this setup, it almost has no resistance at all. It can easily be pulled with one finger now.
I highly recommend this mod to anyone.
It might be hard with the stock intake manifold, but with my custom made extended one, their is plenty of room.
I used a longer bolt through the drive gear cover to keep the clutch roller from wanting to pull to the left when I pull the clutch in.
Here is the link to the original post with all the info and a few different versions, one is mounted on the side of the clutch cover to clear the stock carburetor setup.
Clutch Cable Better Mounting
