To follow up on what the vendor told you about connecting the leads internally, he is incorrect. A circuit basically consists of four connections. A positive and negative input, and a positive and negative output. Obviously the negatives can both go to the same ground, but the positives can not be connected to one another. As far as the green wire, if it just goes to a switch, I don't see how connecting it to either positive would have any effect at all. If anything, its just causing the current to go in a useless loop between the two wires. I'm not criticizing you Harold. You just went by what the vendor said, and that's understandable. I don't know why you were having bad luck with the charger. I do know that all I did was remove the extra wires and make sure everything was connected to the right places, and replace the fuse. The charger is working fine for me, so obviously there was nothing wrong with it in the first place. The generator also works fine. The only reason I am saying this is because the best way to learn about electronics is to research it. I had a member whose name I won't mention give me some bad advice (possibly on purpose) about batteries and charging circuits. I wont get into all the details, but by the end of it I decided to do my own research from then on. When it comes to electronics, you want to make sure you are doing things right. Doing things wrong can only result two ways. One, you lose money on something that doesn't work for you, or two, you fry something, and that can cost you more money as well as personal injury. I'm very appreciative that you gave me these parts to use, but I do feel bad that they didn't work for you. When it comes to people giving me things, I don't have a "your loss is my gain" attitude. So I hope whatever lighting system your building on your new bike works out for you.
