assuming you have a metal drive wheel, weld a nut on the end of it. just hook your drill up to it. You could also get fancy and make a pulley for you drill end and run a belt over the end of your drive wheel assuming you have a little left over. Also you could put a cut off extension for your sockets into the drill and put a large spark plug socket on the end and put it against the tire I suppose. In any case you need to block the tire off the ground.
Just my suggestions You don't need to turn it too fast and probably don't want to.
