I've found a few different online spoke length calculators which seemed to produce good results. The free download "Spocalc.xls" was accurate and easy to use. But sometimes I want to find spoke lengths on a computer without MS Excel installed. I also don't like having to be online to do calculations. With a dial-up web connection and an old, lean machine/system, I have no need or desire to use online calculators on slow-loading web pages bloated with jquery, flash, activex, etc..
So I'm making my own calculator with only simple html elements, script, and an image with a hub diagram to aid in entering the correct measurements. The hub/rim database in Spocalc.xls is nice, but I end up measuring things myself anyways just to be sure, so databases are never very useful for me.
Searching for spoke-length formulas, I found one at http://www.pijin.co.uk/spokecalc.html. I spent quite a bit of time testing it because the results seemed incorrect (by about 10mm) and I naturally assumed I was making some mistake.
After lots of wasted time and frustration, I found other examples of formulas - and could see that they were not the same. There is a good formula with a thourough explanation of its geometry at http://www.wheelpro.co.uk/spokecalc in the file "spoke-length-proof2.pdf".
In the image below, you can see that both formulas are basically the same except for the part in the parentheses after the cosine.
I couldn't get the calculator at pijin.co to work. Maybe it produces proper spoke lengths, but the mathematical formula they show is wrong. Don't trust everything you find online!
After I finish making my simple calculator, I will figure out a way to make it available to anyone here that is interested.
