twelvestringtex
Complaint:
so... does the Grubee Stage III Just come with some shoddy components, or did I screw something up? I broke down today 15 miles from home (in 100 F 90% Houston humidity) and had to pedal all the way home....
History:
The culprit was that the stage III's freewheel had broken down. shortly prior to this, I started having some inexplicable performance issues.
So I pulled off the gearbox, and took it apart to diagnose and attempt to fix my problems, I noticed a ton of evil reeking grey sludge pooled up on the bottom of the gearbox... turns out this sludge was the remnant of a clutch pad that had completely disintegrated and mixed with the lubricant.
My Question:
What's a good clutch I can use that'll mate with the honda motor and the grubee gearbox and clutch bell? The freewheel problem can be solved easily by fixing on a set sprocket to the output shaft and making use of the engager lever whenever I want to simply pedal about.
History:
My Question:
