mew905
I was curious, after cutting my piston I felt like I lost alot of power so I ditched it in favor of a stock ported GT5 jug and piston. After doing that, I noticed... I still havent gained any of the power back. Maybe its because the intake port is so small compared to the GT5-a, but I'm considering the 5a jug making a return to the bike, I thought blowby was an issue but after checking out the piston in the stock jug, it appears to have the same markings as my old piston did.
Here's my proposition: seeing as how my old jug and piston were faster, and both lack any sense of low end power, perhaps I could make up for it with even higher RPM's (dont worry about the bearings, I found an SKF dealer nearby where I'll be grabbing some better ones). My motor is already ported for higher RPM's, mostly because I screwed up with it, but if I make the piston even lighter, I should be able to raise the peak RPM and reduce overall vibrations anyway... cutting the piston window helped alot with them already, so... what if...
Noone saw an issue with cutting the window in the skirt, and it was only as high as the top of the intake port at TDC, so what if I just made it completely flat? I may lose compression (less material) but replacing the bearings I'll "stuff the crank case" as recommended by jag, as well as I'm going to try and get some reeds. Already have the Dax RT carb, SBP expansion pipe, and jag CDI, so reeds and a higher compression head I think would complete the package and perhaps get me my 70km/hr target
