for the front and rear mount, extend the "inside" of both mount parts (spool and clamp) a little longer ,round it and drill all the way through ,then a flat bar w/end holes on both sides w/heavier bolts at the piviot points,,the flat bars would be short ,just enough to allow pivioting ( longer for front mount extream reaches )
There is no reason why this shouldn't work. My question is what is the material? If aluminum then the area of the swivel could be a concern. There is not a lot of material there to take the stress and vibration that can be produced by these little 2 strokers. If aluminum then it needs to be a very high allow. 6061-T6 or better and the sharp corners radiused. Also I would ask what hardness is the bushing. I'm a strong advocate of solid mounting the engine or if a resilient material is used it needs to be as firm as possible. No rubber or easily compressable material. I'm impressed with the design. Good work and good luck. Keep us informed of the progress and testing.
Just a suggestion...buy several bikes that have different frame configurations...then make some mounts. That's what I did...and it's a REAL eye opener.
I have over 20 common bike frames, that I modeled, precisely, in 3D...I also accurately modeled in 3D the complete engine...problems still come up! It is not easy to create a universal part.
Jim
Yes...just like the ones I make.
I have come up with a new design that is even better...It will not be made public until Pirate Cycles & Piston bikes have them In-stock and ready for shipment...I've learned my lesson!
Jim
I just looked all over pirate's and couldn't find any,and the design is similar too yours not exactly just similar,personaly I liked the alum pan the engine bolted too from about a year (maybetwo yrs ago)and then mounted in the frame.Maybe steel would have worked
It breaks down too who has the parts when I need them,
I remember a Deawoo in our shop and waiting almost a month for break parts
