Fuji Moto
After I mounted my engine for the first time i shook it side to side ad i could hear something knocking back and fourth and i found out it was the crankshaft it has about an 1/8 of an inch of play and when the motor is running ut automaticall pulls it to the side with the gears, hard to explain but if you've seen this before you will know what i mean, i tried shimming behing the magnet with rubber but it onl fixed it temporary as it gets pulled to the one side like i explained. Also I cant seem to get my motor to run consistenly it always seems to run different and never really wants to wind out properly and i've tried lots of things like, different oil ratios differnet carb(s) configurations and a bunch of stuff , but i cant get it to run consistent, sometimes it will rev up and do around 45 50 km then i slow down adn hit the throttle again and it will just bog and barely power up any thoughts?
