cranbrook frame
glenz
i recently built 2 kits on huffy cranbrook frames-there is a real easy solution to the front engine mount prob.-simply cut about a 2'' piece of 28mm tube-clamp it in the front mount-and weld the front (lower)-clamp to the frame. it works great and is solid!
You have the small frame mount on your motor? I had no problem with my install with the front mount and on the rear I just put a couple of nuts between the mount and the motor. Ended up being a perfect fit so I don't even need the chain tensioner.
yeah, it's the small mount-it was about an inch and a half short of the frame,so i put the piece of tube in and the bottom of the clamp touched the lower tube just right. i'll send a pic as soon as i download my digital. G.Z.
