Controls for motorized bicycles
twalsh341
Okay, I ride a motorcycle so I'm familiar with all of those "standard" controls, I'm going to layout the understanding I have of MB controls and I'm hoping someone can comment if I've got it all right or chime in if I'm missing something huge...
RH- Throttle grip and a break lever like usual (I'm guessing this is usually front break?)
Feet- Pedal power and rear break (if using a coaster rear break)
LH- Lever for clutch? (twist grip selector if using a 3 or 5 speed hub?)
Questions:
Do a lot of MB have no operable clutch? Meaning it makes engagement by itself and opens by itself?
If you had a rear drum break would you use the above and make LH lever the break? Can all of that even fit on the axle with pedal and drive sides?
What about power for lights from the engine, how could I do that (with a dynamo hub? do I "need" a rear break?
What about taking out the pedals entirely, or is this to get on the moped/motor cycle designation?
Re: Controls for MB
This would be correct. Some people use thumb throttle vs twist
Also correct, although if using a thumb throttle on right, you can keep the twist shifter on the right.
Questions:
Most, if not all the 4 stroke kits do have a centrifugal clutch. You can also get these clutch types for some 2 strokes but I do not know how they work
They make dual pull levers that can have 2 cables run to them although some will not recommend them (potential safety issue). As far as fit, look here. http://www.sportsmanflyer.blogspot.com/2011/08/heavy-duty-drum-brake-hubs.html
That would work or go with rechargeable battery. can run a brake light off front brake lever.
Check local laws on this.
Re: Controls for MB
I've got tachometer/hour counter, brake tail signal head lights, 7 function speedometer, mirrors, kill switch, cellphone holder, twist throttle 5 speed automatic transmission system. You can view my profile to look at my albums.
Re: Controls for MB
That's pretty much the standard.. some have variations based on personal needs or comfort.
Depending on your build, the handlebars can get a little crowded, like mine.
Re: Controls for MB
Here is my setup. I do have an automatic (centrifugal) clutch, so no handlebar lever for that. My front brake lever is on my left, with a built-in brake light switch. The brake lever/hand control unit was from an old scooter or moped, and also had a horn button and turn signals, which I removed due to lack of necessity (hand signals and no horn). I installed a toggle switch where the horn button had been, and the switch controls my headlight. The only thing on my right side is my throttle and of course my kill switch is built into my throttle housing (standard on the kit type throttles, which I am using even though my bike is non-kit). So to recap, left is front brake, brake light, and headlight switch, right is throttle and kill switch. My headlight is powered by two 7.2v nicads, and my brake light by a separate, single 7.2v nicad. My batteries are strapped to my luggage rack with a clamp made of sheet metal, easily removable for wall charging. I have a 15 minute charger, so charging is a snap. With a dynamo hub, you will need a rectifier and voltage regulator to charge batteries.
Re: Controls for MB
picture.php
picture.php
Yes things can get crowded but every control helps.
Re: Controls for MB
Thanks for all of the replies, this has been really helpful. Time to surf the bay for a component list.
