cone lock nuts
gphil
What size cone wrenches does it take on the standard bikes, Cranbrook, Schwinn etc. I am thinking the front is 13mm and rear 15mm Going for some wrenches , the thin ones lol gphil
I believe 15mm is the correct size, I made my own by taking an old 9/16" open end wrench and grinding it thinner and using my 4 1/2' angle grinder to make the opening the correct size, for me that was a great re-purposing of the old wore out 9/16" wrench.
But yeah, I think 15mm is the right one for the standard bike wheels.
I'll measure mine for sure and post back here to confirm if 15mm is correct or not
map
Now that I think of it got me one of those old 9/16 wrenches out there. May do what you did, got the grinders. Thanks , gphil
You're welcome, I had thought about buying a wrench several times in the past but just figured why not just make one from another old wore out wrench, I have all the tools needed to do it so why not save those extra $'s for other stuff.
dance1
map
there are 3 sizes of metric that are common for these - a cheap metric set of wrenches can be had at the 99cent store - grind them thin
Got it so get a set . . . . . Probably the best thing. Thanks those things are critical , just a small amount of tightening needed and easy to over do. gphil
