...not sure why you'd be having problems with searching but here is a link to the results and i'd bet you'll find many answers in addition to the one you seek.hello all. New here and can't do a thread search. anyways I have coasterbrakes. the tab that is on the frame fell of and spun the axial which made the wheel hub wobble. took it apart to fix it and now the whole wheel wobbles. how do I fix it. thanks in advance.
Here's what happens when the brake arm comes loose from the frame & spins around... It unscrews the inside of the brake & spreads the frame apart until the axle snaps into two pieces!!
You most likely have a broken axle.![]()
