IMO the biggest advantages of the CNS carb: Smoother, quiter, lower rpm idle with the deticated idle fuel/air mix screw, And you get a choke on your handle bars you can crack open whenever it sputters a little (Like up a steep hill), Also, its a REAL choke circuit that *adds* fuel, Not takes away air, So using it does NOT reduce proformance untill you make the mixture too rich. I get near full power from startup to shut down, No warmups.
Unfortualy the CNS carb also seems to leak if its even a few degrees tilted back, slowly, So you'll need to mount it tilted forward slightly (Side towards the engine 'low', Air filter side 'high')
