huffypower
Bike had been running great, always starts on first pop. Always just gave it throttle and poped the clutch and i was off. Never even had to use choke. Was cruising on it the other day and it just died at 20mph. Couldn't get it restarted. Messed with it for a good bit And found if i petal like crazy with no throttle it will try to start and very slowly roll on throttle to keep it running but very poorly having to help petaling up even slight hills. Figured maybe plugged. Took carb apart and cleaned it all. Reinstalled with new gas, filter and even sandblasted sparkplug even though wasnt that bad. Still ran very rough and extreamly sluggish but gradually became better. Here and there when i pulled the clutch it would roar to wot even though throttle plunger was at idle position looking at it with air filter off. At one point it went to wot then slowed down, at that moment i seen fuel flowing thru my clear fuel line like the bowl had been empty but then filling.
Took it apart again and cleaned it and all the problems are still intermittant every once in awhile but still dont have the power i used too. It has always sputtered some starting out from petaling until it grabbed the powerband and took off but now way worse.
The only thing i didnt remove when cleaning was the float and float level needle. Perhaps is that the root of all my problems being partilly plugged?.
Dont mind the CNS when running properly but a pain in the a## when not. Brass plug removed for adjustment. Thinking about replacing with a NT but have heard gripes of them not accerating as fast and would defeat the "being able to fix anything on it" factor. Lol
Input please. Thanx
Input please. Thanx
