Clutch Question
longduckdong
Just a newbie question. Installed a Boygofast kit on an Onyx 29 inch bike. Everything is assembled with the exception of the throttle grip and clutch lever since they won't fit my handlebars. So my question is shouldn't the rear wheel spin freely when the clutch is arm engaged? When I position the clutch in the idle position I'm still fighting engine compression. I pulled the cover when installing the chain, could have fouled something when i reinstalled the cover and arm?
there is a rod and a ball bearing in there.doesent hurt to put a little grease on them whenever you take the cover off.
the lever connects to a shaft with a flat on it,as shaft turns,it pushes bar into housing and bar presses ball to activae clutch.
cable must be adjusted with no slack in order for it to operate correctly.
you may need to adjust clutch under the cover on the other side,dont bother until you have clutch mounted on handlebar.it needs to be somewhat useable.
