Hello, I'm new to the site and just finished a first build. The kit was from boygofast and the motor runs real good so far, but I'm still on the first tank of gas. I don't understand the clutch. It works fine, by that I mean it doesn't slip or chatter,engages nice and smooth, and the lever pulls in pretty easy. when it sits for any length of time, it wont disengage. What I've had to do before a ride is get on and while holding the lever in, rock it back and forth slightly until I hear this click, or a better word would be snap. Then it's fine till you park it again. I did a search on here and after reading a while found a guy with similar symptoms. Norm told him his chain was loose and was binding on the front sprocket. I readjusted to get 1/2" - 3/4" slack but it's still the same. Other things I've tried was taking the lever side cover back off to make sure the little rod and ball and actuator cam had grease and they do. I also read about putting grease down into the threaded hole where the cable guide goes. This I did not do. I wasn't sure how much to put in there. If that cavity is open to the friction pads, wouldn't grease get on them? What I've done as a temporary solution is to park it with the clutch pinned in. Then it's ok for the next ride. I don't think this is normal, but I'm inexperienced with these. Any thoughts? Thanks, Mike
