WaterDog
I have a zoom 66cc slant motor, pretty standard design. The clutch arm faces the back tire when engaged. To disengage it needs to be pulled 90 degree to the right so that it points toward the original sprocket. Ok, thats the easy part and it works great. But this is about a 2-3" motion. The clutch handle only pulls about 1" from full open to total closed position. How is the clutch supposed to be disengaged with the handle? The cable is tight and it works correctly except there is not even half the pull distance needed to engage the clutch. Looking at the distance the clutch ar
M needs to turn, nobodys hand would be big enough to squeeze such a handle.
