quaternium
I have a two-stroke China girl 49cc. Suddenly, while riding, I had loss of power to the drive and a high engine rev, and pedaling was EASY / not the usual tension I'm used to with clutch engaged. I took off the clutch cover and noticed the large screw holding the small bevel wheel is loose. Could that be it? I'm not even sure if this is a clutch problem. The clutch handle moves the clutch plate as I assume it should.
Bear with me, please, as I'm entirely new to working on these motors (or any motors)
Would this be considered a total compression loss? Clutch slipping? I'm not sure if I should/have to tighten the screw holding the small bevel wheel? Or start messing with the clutch plate and flower nut? Sheared woodruff key? I'm lost.
