midwestmayhem
So the clutch is slipping on the 66cc china girl.
This is all that I have tried.
All the clutch parts have been cleaned with brake cleaner, pads and pressure plate dressed down with sand paper to remove the glaze.
Adjusting the flower nut didn't help, the only effect it had was were the position on the clutch arm with the cluch was released.
Inner spring- No matter how tight I tighten it clutch still slips. I tightened it 1/2 turn at a time untill it was to the point that the spring was completely compressed. I left the cable dissconected during the test. Tried adjusting flower nut at each test. As previously stated it still slipped.
So I think I'm down to replacing the pads and/or inner spring. I want to find some stronger than what it came with. I've read that some have had luck with mcmaster but they don't mention what type of material they used, I saw five differnt types on their site. I've also read that some have suggested automotive valve springs, has anyone ever tried it? What lb spring was used?
Any help appreciated, thanks
