Yes, by exerting pretty good force using thumb, the plate lifts, and goes out of gear. So I just need to make some adjustments then and pull the cable tighter and readjust the brass stop, also probably some adjustments at the clutch handle.
Any other suggestions?
You make a good point with the o'clock discussion, you are referring to a straight clutch arm.
Thanks so much for y'alls help, really appreciated.
Brad
Brad
