chain to frame clearance.
a.graham52
hello all. iv got a stock china girl. no extra add ons. the upper drive chain rubs on the "a-frame" that goes to the rear wheel. both of my bikes have done this. i can see clear marks in the paint. i tried to put the on the upper chain but it keeps coming loose every time the engine is started so i assume that way is not an option. rear sprocket is teeth are dished "in". :-||
Does the chain touch the frame all the time or just hits when you're riding?
How tight is your chain? You want 1/2" to 3/4" of slack.
No, the tensioner won't work on the top chain run. That run is under stress when the engine is driving. The tensioner, if you have to use one, should be on the bottom chain run only.
i would say there was about that much slack in the chain. i have maybe an 1/8" of clearance vetween the chain and frame. i rode for about 5 minutes today and the paint it already gone off that area on a brand new bike. and its aluminum so i dont want to go too long like this.
If the engine is mounted correctly, that is centered in the frame then the chain shouldn't be hitting the seat stay unless the rear wheel/sprocket is too far to the left.
Can you post a photo of your installation showing chain/sprocket alignment looking forward from the rear of the bike? That would help us make some suggestions.
How about a couple of washers on each side of the axle inside the frame? May push the frame out just enough to clear the chain........or use a slightly smaller rear sprocket......
Both good suggestions but I still would like to see a photo or two of the install.
The best way to cure this is by using a small scissor jack from an import car to carefully spread the frame for clearance.
Use wood between the jack and frame to spread the loads and avoid denting or kinking the frame tubing.
Use a bare axle or nut and bolt to hold the dropouts at the normal wheel spacing as you spread the frame. Be extra careful on aluminum, but this works very well and is easy to do.
Tom, You have seen the frame type. They have a coke bottle stay shape that curves in toward the wheel, then back out at the axle. LOTS of aluminum and many lower end steel frames have this shape.
My Original Pig (NEXT) required this mod to stop the chain rubbing the seatstay.
Took all of 10 minutes to fix.
Took longer to get the wheel off than fixing the frame did.
I've never used a rag mount but can you put a couple washers behind it, I've had to do that for a drive sheave to clear tires/ chain stays?
I've never tried a jack but I did throw this together real quick. It's just a 1/4" aluminum turn buckle that I welded on a couple of saddles to fit frame tubing. It can go on the chain or seat stay and when you turn it it spreads the frame.
I use it when I install chain tension adjusters that take up some space on the rear axles.
I actually though about doing something like this Tom, but it was too much effort for a tool I seldom use since I already have the screw jack.
i added 3 washers to the left side of the axle. all is good now. also put the axle "lower" in the bike to add even more clearence.
by taking a 2x4 and placing it within the frame putting the tip of the 2x4 on the seat post and pulling out on the opposite side of the frame where the back wheel mounts you can widen the back area just a little bit not much just a little bit and that should give you the clearance that you need
You may want to create a new thread Denis, I used a hydraulic power pack to spread the seat and chain stays of my Sportsman Flyer frame, to get perfect chain lines. Mind you, you are resurrecting a 7 year old thread.
Carry on sir.
