deacon
minor bike philosopher
When pigs (with or without lipstick) fly lol....
I shot you some pics of the chainsaw mount. Let me see if I can't do a walk through for you.
A couple of things that are noteworthy in this image ... The angle iron is used backward so that the engine sits on it. As I explained before I drilled holes in the bottom of the plastic case and used metal screws to hold the motor in place. If they ever get loose I will use loctite on the threads next time.
Also there are a couple of metal bars used as top braces so the engine does not fall over backwards. You need to support the top so it doesn't twist.
Also note the two L brackets bolted together to make a harp to tie the engine mount to the opposite side of the bike. Scissor hinges prevent the engine from twisting to much from it's own torque.
Note also that the engine mount is attached to the wishbone of the bike frame. It is on a hinge to allow movement up and down. The hinge is attached to the angle bracket.
The threaded clutch holder was just welded to a steel axle peg to make a drive wheel. I also have a plain pipe wheel that I can use if this axle peg does too much damage to the tire. The nut for that one came from a similar chain saw. I would take the threaded clutch nut to a good lawn mower parts store and hope they could match it with a nut. In case of the poulan I think it is a 11mm left hand thread. Same is probably true for the craftsman 42cc I think.
This should give you a better idea of the harp, motor mount, and hinge relationship. The verticle bar is where the clutch cable hooks up to. Helps with the lift angle.
This will give you an idea of the sandwich effect of how I hook my engine mounts to the frame. The frame is too small to drill and I don't weld. So I use a three point tie down. In this case I could get three points since i also went with a smaller wheel. One bolt (or two if you have room) in the center of the wishbone and then one on each side of it. (tighten them down evenly)
If you want pictures of the clutch with cable let me know I'll shoot you some.
