Chain Keeps Jumping Off the Motor
Hannibelle
Georgia
This is my first electric bike build. I used a 24v Razor scooter motor and custom sprocket. The motor chain keeps jumps off, especially when on full power. There is a little bit of slack in chain by half a chain link. How can I fix this?
2door
Moderator
Staff member
16,337
156
Littleton, Colorado
Chain tension probably isn't the issue but sprocket alignment is. Unless the drive and driven sprockets are perfectly aligned you're going to have chain problems. A very loose chain can be a problem but alignment is usually the culprit.
Also a chain that is too tight can also give you problems. Roller chain requires some slack, usually about a half inch is good.
