Humsuckler
well i sat down this evening to get this clutch installed on my spare engine. pull start was a 3o second job. it works great. onto the clutch kit.
WHAT A ****ING PIECE OF ****.
the cover plate, didn't fit without enlarging holes, no problem.
the clutch assembly itself, that is now stuck onto my crank so tight it will never come off. it only made it halfway on after 20 minutes with the impact gun. i figured it would slip right on with the first pull of the trigger since it was liberally lubed with antisieze compound. wrong. by the second squeeze the clutch pads fell off and the bell pulled off now im mad eh' i start up my compressor and pull out the 1/2" impact (this is the one that halus off lugnuts like they are melted steel. no dice. whatever, its far enough to mesh gears. so i put the bell on and the one way bearing pushed out, try and get those pins in. just try. well at this point i made the mechanic's call that this project is now totally fubar. i swing my pursuader with 6 strong blows directly center (thus pounding the **** out of the crank's main bearings i assume) and now i have one un-used piece of **** china made centrifugal clutch kit, hammered into oblivion, installed on my once-was-a-backup-running-66 probley now never-going-to-run-right-EVER-again, scrap engine.
at least i have a spare set of clutch pads.... and magneto. and a cylinder. the rest is about as useful as a blown up homelite.....
**** 2009.
**** 2009.
