Centrifugal Adjustment Help!
mjharden1
Hi guys, I had a pull start - Centrifugal clutch on my 2 stroke.
It was working fine for a while but will not drop into gear now. It starts and revs in neutral.
Anyone know how to adjust this? I have found other stuff online to adjust centrifugals but they have a bolt with an adjust screw in the middle, this does not.
photo attached.
Thanks zpt
Maybe your manual clutch pucks are glazed and its slipping? Or the flower nut needs to be adjusted on the manual gear. Like rohmell said, the CC works by simple physics.
Yeah, that could be happening too. When you put on your CC did you make a notch like the manual clutch so that little key thing on the shaft can fit on the CC?
